Measuring and checking standard tolerances
NC8255
NC program for measuring and checking a standard tolerance in the uniform shaft and uniform hole systems to verify that the measurement result is within the tolerance.
The control then displays the status of the fit, the measurement result, and the tolerance dimensions in a window on the screen.
Supported by the iTNC 530 with NC software 340 49x-07 and 606 42x-02 or higher
iTNC 530 NC program Machine control Measuring / probing
